#1 Posted : Wednesday, April 22, 2009 4:21:16 PM(UTC)
Installed new control module 5303918340, a white box with built in readout and touch control together with wiring harness and thermisters.
Control worked fine initially and opened the damper door, came back later to a warm refrigerator and damper door closed.
Checked everything, I guess just a bad control. Hope someone has seen this before! Thanks in advance.
#2 Posted : Thursday, April 23, 2009 5:08:47 AM(UTC)
Found the problem. The fridg thermister is near the damper door. The damper door opens all the way, then closes all the way, never half way, a simple switch on the damper controls this.
I found I didn't prevent air from blowing directly on the thermister due to improper assembly! This is real easy to do.
