Discuss
water tube connector
 in
Refrigerator & Freezer Repair
ice maker water supply tube in back of side by side refrigerator sprung a leak . there is a connector in
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » water tube connector
  #1 (permalink)
Old 12-04-2007, 08:24 AM
justone justone is offline
Junior Member
justone is on a distinguished road
Default water tube connector
Model Number: gd5phaxlq01   Brand: Whirlpool   Age: 1 - 5 years
ice maker water supply tube in back of side by side refrigerator sprung a leak . there is a connector in the line. how do i remove the bittier end of the tube from the inline connector part # ap3085805. i don't need the entire supply tube , i only need the lower section that sprung the leak. i just need to know how to seperate it from the connector.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-04-2007, 12:22 PM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
Take your finger tips and press in on the locking ring on the end of the connector you want to release. The ring will be the little part up against the water line and may be hard to push. It will only move a little. Now at the same time pull the water line out. When you replace the water line, ensure to push it in until it stops and it will be water tight. The connection at the water valve will have the same kind of connector.
TechnicianBrian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice maker - water freezing in tube lannym Refrigerator & Freezer Repair 1 12-01-2007 04:07 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
