Quote:
Originally Posted by 102991
You will have to remove a couple of screws behind and to the left and right of the temp control levers in order to remove the plastic trim. The actual Adaptive Control Board housing has clips on it. Take it slow with a flashlight and it should pop right off. By the way, the ACB took care of the problem and the fridge (and freezer) work like a champ! I did find what appears to be
a deterioration of the plastic coating on the old board and I'm wondering if it was just shorting itself out???? Anyway, good luck. It's a piece of cake.....
Thanks! I looked through some of the other posts awhile later and found a similar description. You're right...it's not difficult...but we should add that it's necessary to unplug the refer. The board is still drawing current even after turning off the unit. I've had some recurring icing issues on the condensor coil that I thought might be a faulty heater element but after reading other posts, it may have been a faulty ACB causing it all. My old one would start buzzing (bad relay box on the board) and would not stop unless I unplugged/plugged the refer. I was able to get it out without issues and my old one was in a pocket in the back right corner of that housing. It wasn't attached to anything but just laying in the corner space. A simple case of plug and play. I've read that others are in a different style of plastic box and are held in with screws. ?? It's all working great and I'll see if my condensor icing problem returns or not.
Thanks for your help...Les
