tvlensman
#1 Posted : Friday, September 23, 2011 2:29:54 PM(UTC)
tvlensman
buzzes like heck. pretty much all the time. seems like a sheet metal thing. buzz goes away for a bit if i lift unit from the side. i've tried re-leveling but no joy. any help would be greatly appreciated, especially by the kids who hang out in the family room.... thanks, michael
#2 Posted : Saturday, September 24, 2011 2:37:16 AM(UTC)
Remove the rear cover to see if something has come loose.
Check the compressor mounts.
Be careful as there is voltage back there.
tvlensman
#3 Posted : Saturday, September 24, 2011 10:47:34 AM(UTC)
tvlensman
yup seems to be the right rear compressor mount. re-re-leveled the thing over a piece of carpet and seems to have quieted itself. i figure it will buzz again soon. would i tighten, loosen or try to replace the mounts???
#4 Posted : Saturday, September 24, 2011 1:04:02 PM(UTC)
Try tightening first just half a turn at a time.
Also try different mount bolts.
Only do it till the buzz stops.
If that does not work try loosening.
Do not over tighten as you may crack/destroy the old rubber mount.
I do not like moving a compressor if it can be avoided as there is always a chance that you will create a leak in the sealed system and the unit will be toast.
