I hooked up a new water supply line to the refrig. The water dispenser works fine. The ice maker is not working. I pressed the on/ off switch a couple of times and the ice maker had several hours to start. No ice. there is a white plastic lever bar, which doesn't really move much in front of the icemaker. I don't know it's function other than it is like the wire bar in many icemakers, which functions as an on/off switch. Any ideas?
