You have been a member since:: 9/21/2011(UTC) Posts: 1
When the light bulb is inserted into the socket the panel options (water, ice, crushed ice, etc) do not work. When I remove the light bulb from the socket the panel options all work (water, ice, crushed ice, etc). When I place the bulb into the socket the bulb works but again, the panel options do not.
Appreciate thoughts and ideas.
pictures attached...(unable to upload)
Thank you, OneFunZ71
