Discuss
Ice Maker doesn't work, water is slow
 in
Refrigerator & Freezer Repair
My Frigidaire, model FRS28ZGEW!, is not making ice. The water in the door flows very slowly. The icemaker used to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker doesn't work, water is slow
  #1 (permalink)
Old 12-02-2007, 12:49 PM
CroisanMountain CroisanMountain is offline
Junior Member
CroisanMountain is on a distinguished road
Default Ice Maker doesn't work, water is slow
Model Number: FRS28ZGEW1   Brand: Frigidaire   Age: 5 - 10 years
My Frigidaire, model FRS28ZGEW!, is not making ice. The water in the door flows very slowly. The icemaker used to make hollow ice and now makes none at all. I did work on the water main last summer to add a shut off valve so it is possible a bit of dirt or clay got in the line and traveled to the fridge. I'm pretty handy if I know what to do. I appreciate your advice.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-02-2007, 03:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is the old water filter which is got clogged, causing restriction to water flow.
- The part number for the water filter AP2591529
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-02-2007, 05:29 PM
Junior Member
Default Water valve looks to be the problem
Gene, I replaced the filter long ago. That didn't work.
I read your reply to the kitchenaid icemaker water not pumping. So I took a look at the water valve (AP2114949).
I disconnected the incoming water line to the valve and checked it. The water flowed strongly as you would expect.
I put it back on and then took off the water output lines. My helper put a cup in the door to pour water. It activated the valve and water only trickled out of the water valve. Given that, it appears the water valve is failing.
  #4 (permalink)
Old 12-02-2007, 05:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In such case, most likely the problem is the water valve.
Replace it and post the result, please.
__________________
  #5 (permalink)
Old 12-02-2007, 06:02 PM
Junior Member
Default I'll let you know
Ok, I'll let you know how it goes
  #6 (permalink)
Old 12-08-2007, 11:03 AM
Junior Member
Default
Gene, I replaced the water inlet valve with water strainer. Now water vigoursly exits the water valve so that is an improvement but... After we got the air out of the line, water did gush out fast for a moment and then back to a trickle. So I replaced the filter again. I heard the water fill a resouvor a the top of the fridge. When inserting a cup, water ran vigously into the cup again for a moment and then it went back to a trickle.
The ice maker is not calling for water yet. It appears to be more than one problem but the new valve definately helped.
UPDATE==============
I removed the filter and placed a cup below the open filter. I called for water in the door and it came out of the filter assembly vigorously. So it's clear the water slows down to the door from the filter forward.
Also, the icemaker water input tube was frozen solid. I took it out from the back of the fridge and ran warm water through to clear it. However it still is not calling for water.
Back to the brand new filter, I tried blowing and sucking on the new filter and it's difficult to get air through it. I had purchased a batch of 8 filters and have 5 left but I'm leary about opening them all up. I still need help!
  #7 (permalink)
Old 12-15-2007, 02:50 PM
Junior Member
Default
Gene. It now works! There are two water valves in the Refrigerator. (located in the back, about 3 inches above the floor. One on each side.) Both needed to be replaced. Once I did that, the water ran freely at the door. It wasn't the filter at all. I did sand the contacts on the existing water valve and my ice maker started making ice again, so apparently the water feed side of the water valve was not working. There is a yellow and a green electromagnet that operates each valve. On the second valve, green feeds the icemaker and yellow feeds the water.
  #8 (permalink)
Old 12-15-2007, 07:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
Merry Christmas!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge OK Freezer temps vary widely slow ice and slow freezer fan start shado118 Refrigerator & Freezer Repair 2 04-24-2008 06:07 PM
ice maker no water mpmc Refrigerator & Freezer Repair 3 11-07-2007 01:48 PM
VERY slow water and small ice from door Davidg Refrigerator & Freezer Repair 2 10-31-2007 04:13 PM
ice maker works but slow jeffrey Refrigerator & Freezer Repair 1 08-10-2007 11:02 AM
Water/icemaker lever on door will not work boldpilot Refrigerator & Freezer Repair 3 07-24-2007 07:09 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
