I have a Broich side-by-side refrigerator/freezer (model # 2699A) in which the evaporator fan is not running (I believe that the Broich is actually an Amana, but am not sure).I defrosted and dried the freezer section and then replaced the evaporator fan. The fan worked properly and the fridge and freezer worked fine until the first defrost cycle. The defrost cycle worked fine, except when the cycle completed, the evaporator fan did not come back on to move the cold air back in to the fridge.
Can anyone tell me where the power for the evaporator fan comes from, and how to change that component? I'd also appreciate any other thoughts or ideas of what the problem may be.
Thanks, Bob
