I need a wiring diagram for the compressor on this freezer so I can connect a quick start to it, I need to know witch post on the compressor is common ,start and run.
Thanks ken R.
Your model # will not work, just check the id label, also tell us if the label indicates R12 refrigerant, or R134A
here are all the # that are on it Factory # 47F12671413 Model HMG892400A BM# 4U68A R12 10.5 oz Eltric 115 V 60 HZ 100 V 50 HZ
All the old R12 compressors had the common on top, start on bottom left, run bottom right. They drew like 3 amps which is around 1/4- 1/3 hp.
