Discuss
refrigerator trips breaker
 in
Refrigerator & Freezer Repair
Have a side by side that cools fine for the first couple of hours then the breaker trips. I am
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » refrigerator trips breaker
  #1 (permalink)
Old 09-17-2011, 06:34 PM
Junior Member
case310350 is on a distinguished road
Default refrigerator trips breaker
Brand: Admiral   Age: 1 - 5 years
Have a side by side that cools fine for the first couple of hours then the breaker trips. I am thinking the defroster is coming on and staying on. Not sure where it is located. would like a second opinion on best way to troubleshoot.
  #2 (permalink)
Old 09-19-2011, 05:02 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
To confirm or eliminate the defrost heater, disconnect it. tape up the connection to the heater so that it cannot short to anything and give it a try.
Most heaters are basically just a length of resistance wire so it cannot short internally.
Check that it is not shorting to the frame.
Check that the wires feeding it are not shorting to each other.
I doubt it is a defrost problem as usually a unit only goes through defrost every 8 hours or so.
Also is it blowing the breaker in the house electrical panel or is it tripping a GFI?
__________________
  #3 (permalink)
Old 09-19-2011, 07:22 PM
Junior Member
Default
its admiral asd2514ar. its tripping the gfi after about 2 hours, I have no regular socket without gfi. whats your guess
  #4 (permalink)
Old 09-20-2011, 03:47 AM
Senior Expert
APP Volunteer
Default
If it is an in receptacle GFI I would try it on another outlet.
This GFI type does go fairly often.
If OK
Next would be to open up the back of the freezer and check that all connections cannot provide a connection to the frame. By this I mean that there is moisture/ice that could provide a current path. Dry them off and check them. Do this with the unit unplugged.
This problem can be very difficult to fix as finding the current leakage can be near to impossible.
After the freezer is checked nest would be the compressor start device.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Breaker trips after 45 Ken Martin Dryer Repair 3 07-27-2011 04:08 AM
Breaker trips after 45 Ken Martin Dryer Repair 1 07-26-2011 05:09 PM
trips breaker dstallings Dishwasher Repair 0 08-23-2009 07:39 PM
Breaker Trips rocker5164 Dryer Repair 3 10-13-2008 12:30 PM
Breaker trips jim1958 Dishwasher Repair 3 11-12-2007 06:53 PM
