changed adc now need too change damper motor. wiring harness only has too wires gray and red for new motor, new motor has 4 plugs too inside too outside, the gray and red wires are togeather in a plug? do they plug to inside plugs or outside plugs, i have tried it both ways , the damper still stays open all the time, getting the fridge too cold. freezer is 0 degrees. this a side by side new damper new adc any suggestions.
Originally Posted by: jimmybass changed adc now need too change damper motor. wiring harness only has too wires gray and red for new motor, new motor has 4 plugs too inside too outside, the gray and red wires are togeather in a plug? do they plug to inside, plugs or outside plugs, i have tried it both ways , the damper still stays open all the time, getting the fridge too cold. freezer is 0 degrees. this a side by side new damper new adc any suggestions. fridge work fine before the adc went bad, don't know if i wired wrong or what . can someone give me some help on wiring harness
