| » trouble shooting guide for my ice maker |
Model Number: ET8LFKXKQ02 Brand: Whirlpool Age: 5 - 10 years
Hi, I am hoping I can find a guide to trouble shoot my ice maker... the water supply line is not crimped... no ice is produced... no previous ice is jamming the motion of the discharge fingers... I am guessing the water valve that controls the "refill" cycle is plugged or the sensor to excite the refill valve is not working... I have heard the ice discharge gear motor try to work and have seen the ice discharge fingers rotate... can you help me with your suggestions...
Thank you - Rich Ads By Google Related Models |
Hello. Check and make sure the fill tube for the ice maker is not frozen over. Also, make sure the water is turned on going to the refrigerator. If so, and the ice maker is cycling properly, you will need to replace the water valve. Hope this helps.
Part number: AP3103467
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You can stick 115 volts to the icemaker solenoid in the back for 6 - 9 seconds to see if the icemaker mold fills up. If ok, and the freezer temperature is below 15 degrees, you probably have a bad icemaker, bad mold heater connections.
__________________
| Display Modes | |
| Ice Maker trouble shooting | Pat13 | Refrigerator & Freezer Repair | 1 | 12-06-2010 12:26 PM |
| Need Trouble Shooting Guide | steve'smrfixit | Dryer Repair | 1 | 10-11-2010 12:26 PM |
| maytag trouble shooting guide | cjch | Dryer Repair | 0 | 06-30-2010 11:31 AM |
| Need ice maker trouble shooting guidance | Fokkersauras | Refrigerator & Freezer Repair | 8 | 03-06-2010 05:51 PM |
| Need Owners Manual/Trouble shooting guide | Frank Jones | Oven Repair (including Ranges and Cooktops) | 0 | 10-26-2008 04:04 AM |
