I am assuming you mean the compressor fan and the evaporator fan.
[COLOR="DarkRed"]Yes, the compressor fan and the evaporator fan. The compressor seems to maintain it's very warm outer temperature and running a lot too. It seems that everything is running constantly. The main reason I advanced the defrost timer was to see if the "clicking" noise from that area would stop. It's just the faint ticking noise that I thought the timer made, but I don't remember it ticking all of the time? However, it is still ticking all of the time.[/COLOR]
Definitely won't help. If the coils are dirty the compressor cannot efficiently remove heat from the unit. Even dirty condenser fan blades or a clogged front kick plate can effect cooling.
[COLOR="DarkRed"]So, should I remove the condenser to clean it? It looks like a pain to remove? The fan blades were pretty clean. We vacuum the front kick plate and underneath the unit often due to our furry kids ;)[/COLOR]
It does sound like a low freon problem or a partial plug in the sealed system.
Then when the liquid freon enters the coils it is used up quickly and there is not enough of it to cool the rest of the coil so does not get the unit cold enough.
[COLOR="DarkRed"]I don't mind having freon added, but it sounds like it could be on ongoing issue. The whole sealed system is a new thing to me and I don't know much about it. I will search for more information about it. [/COLOR]
I checked it and it worked for me so I do not know what the problem is.
try Googling "applianceaid.com" to find it.
Then go into the "Appliance Repair Ad" section.
[COLOR="DarkRed"]The link worked, but I didn't see the example pictures you mentioned.[/COLOR]
That is up to you, I cannot say for sure as I am not there so am trying to give you as much info as possible so you can make an educated decision.
From your description I would not but but a new unit is expensive so you want to be sure that the problem is a sealed system problem.
[COLOR="DarkRed"]I realize you aren't here, but your knowledge far surpasses mine on this. I just don't want to throw $$ down the drain. I guess it might be worth a call to the local repair person to ask a few questions. Just frustrating as we recently moved here from Arizona. We don't really know anyone and those we have spoken to locally are just not the most "customer service" oriented people![/COLOR]
I do not give advice on what to buy as it would probably break down a week after you installed it. That is just how my luck goes.
[COLOR="DarkRed"]I completely understand about the luck ;) Was just hoping for some general info. Too bad things aren't made like they used to be! Sometimes it seems it's better to buy used than new.
[/COLOR]
I would stay away from older GE's that use a control board. Just take a look at this forum and it becomes self explanatory. Make sure you see the thing run. Do not buy fancy in most cases it is just more things that can go wrong.
I am still a big fan of non-electronic controlled units.
[COLOR="DarkRed"]Thanks for the tip on GE's. We don't want fancy, just basic with lots of space. We like the side by sides, but it's difficult to find them without the water and ice[/COLOR].
[COLOR="DarkRed"]Thanks again for your information. If you think of anything else, just let me know. I'll be sure to post any updates :)[/COLOR]
Read more:
http://forum.appliancepartspros...p;p=535463#ixzz1Y7kHlYFZ http://forum.appliancepartspros.com
