Discuss
Kenmore Fdreezer Not Cold Enough
 in
Refrigerator & Freezer Repair
Hi, My Problem Is That My Freezer Is Not Cold Enough. A Thermometer Inside Shows A Temp Between 18-20
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Fdreezer Not Cold Enough
  #1 (permalink)
Old 08-02-2007, 03:37 PM
SGTEJF53 SGTEJF53 is offline
Junior Member
SGTEJF53 is on a distinguished road
Default Kenmore Fdreezer Not Cold Enough
Brand: Kenmore   Age: 5 - 10 years
Hi, My Problem Is That My Freezer Is Not Cold Enough. A Thermometer Inside Shows A Temp Between 18-20 Degree's Farenheight. Some Things Like Bread And The Like Are Semi-soft. The Thermostat Is Turned Up To Maximum. Any Suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-03-2007, 11:58 AM
jdman jdman is offline
Member
jdman is on a distinguished road
Default
Should be reading-5 to+5. Clean coils and fan ant back bottom of unit very weel. If these are dirty, it is difficuilt for it to remove heat. Could also be a slow running evaporator fan motor or bad cold control. Are you sure the temp is turn up all the way or did you turn the dial up for the damper that sends cool air to ref side? Just asking because I have hade many calls in the past where this was the case.
  #3 (permalink)
Old 08-03-2007, 12:55 PM
Junior Member
Default Kenmore Freezer Not Cold Enough
Thanks Jdman For Responding. The Answer Is That The Freezer In Question Is An Upright Freezer With No Refrigerator. I Looked Underneath And It Looks Pretty Clean In There. The Thermostat Is Turned Up To 5, The Highest It Will Go. The Model Number Is Kenmore # 253.9284011. Thanks Ed
  #4 (permalink)
Old 08-03-2007, 12:58 PM
Member
Default
Sorry. Could be low on refrigerant. Does the compressor run continously? Also could be the cold control.
  #5 (permalink)
Old 08-04-2007, 07:06 AM
mazzov mazzov is offline
Junior Member
mazzov is on a distinguished road
Default
I've got the same problem. Same model type. Except it is speratic. It will work fine for a few days then I notice there is water on the floor and everything is on the soft side but it's still blowing cool air.
What did you wind up doing.
  #6 (permalink)
Old 04-26-2008, 09:47 PM
lamallamo lamallamo is offline
Junior Member
lamallamo is on a distinguished road
Default
Yes, I just vaccumed a lot of dust out of bottom and cleaned and it is still not cold (refrigerator) Freezer is making ice but smal pieces
  #7 (permalink)
Old 04-26-2008, 09:50 PM
Junior Member
Default
Ice maker if making ice but the temperature in the refrigerator and freezer not cold enough. Some things in freezer also melting
  #8 (permalink)
Old 04-26-2008, 09:51 PM
Junior Member
Default
Yes water is getting to ice maker
  #9 (permalink)
Old 04-26-2008, 09:52 PM
Junior Member
Default
what could be the problem, freeon or what?
  #10 (permalink)
Old 04-26-2008, 09:56 PM
Junior Member
Default
Quote:
I am afraid that the refrigerator is not cold enough and I will get sick from eating the food. The Freezer is cold but not keeping, for example, ice cream solid. It turns to mush
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
