| » Kitchen Aid Control Board |
Model Number: ksrp25fsss01 Brand: Kitchen Aid Age: 1 - 5 years
The light is out on the control board for the temp setting for the refrigerator--the one for the freezer is still on. When I press the refrigerator setting button, it beeps but no light shows. Will the temp setting still work properly? Is it just a matter of not seeing the little green light to tell me what number it's set on or can this actually affect the cooling system?. thanks so much for any help
It could be either one of the above. Get a fridge thermometer and measure the temperature in the fresh food section on a middle shelf. It should be around 40 degrees F. Then raise it or lower it to see if the actual control works. Give it at least 8 hours before rechecking it. That will tell you if the control still works. Have you tried unplugging the unit for 5 minutes or so to see if it will reset?
__________________
Quote:
Unplugging hasnt helped. I have a thermometer in the fridge, and it wont get off 43-44 deg. I pressed the fridge temp control button and rechecked the next day, still same temp. There is some frost on the back panel in the freezer-I defrosted the coils and less than 24 hrs later, the frost was on the panel again. Does the board affect the defrost system too? I was hoping that it was just a burnt bulb since the little green indicator light was out-it still beeps when u press the button to adjust the temp, but the temp doesnt change. thanks again |
Replacement parts for WHIRLPOOL KSRP25FSSS01 REFRIGERATOR | AppliancePartsPros.com See the attachment for the tech sheet Yes the control board also controls the defrost.
__________________
Quote:
So its possible that the board works well enough to keep the fridge temp at 43 deg, but not well enough to get it lower? Thanks |
| Display Modes | |
| High voltage surge damaged the control board,replaced board,compressor still not runn | shillion | Refrigerator & Freezer Repair | 0 | 11-16-2010 01:18 AM |
| Replacing Kitchen Aid Control Board | paul_8788 | Oven Repair (including Ranges and Cooktops) | 0 | 10-22-2010 12:45 PM |
| Kitchen aid control board | abtrman | Dishwasher Repair | 2 | 03-10-2010 01:37 PM |
| Kitchen Aid:Switch Panel Membrane or Control Board? | Pirate6381 | Dishwasher Repair | 1 | 11-08-2009 04:19 AM |
| Kitchen Aid Control Board Replacement Help | tjgx100 | Microwave Repair | 2 | 12-08-2008 01:21 PM |
