I noticed that the light did not come on when the freezer door was opened. Further checking revealed a small ice flow (drip) that froze the light switch shut. I can't tell where the leak is coming from I hit the switch with a hair dryer and cleaned the ice off of the portion of the tray that depresses it and it worked for a while. But, it is icing up again. If I leave the ice maker switched to the off position, it eliminates the problem until I switch it back on. Any ideas? thanks Read more: http://forum.appliancepartspros...issue.html#ixzz1Xwri1iPQ http://forum.appliancepartspros.com
