door seal extremely hot refrig side
I cannot find any info on the given model number.
Often a hot chassis is due to dirty condenser coils, a non working condenser/compressor fan or dirt/dust preventing good air flow under the unit. |
THIS FORUM IS DEAD!!!!!!! |
The compressor fan motor fixed both problems 1 hot door seals 2 now have ice on regular basis!! THANKS
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause. |
