Yefim
#1 Posted : Monday, April 13, 2009 10:30:35 AM(UTC)
Yefim
Hi. In refrigerator at the buttom of the evaporator is accumulated ice and condenser's pipeis frozen. I cleaned up twice but ice is builed up again. What could be a problem? Thaks, Yefim.
woodchuckie
#2 Posted : Monday, April 13, 2009 3:32:57 PM(UTC)
woodchuckie
If the evaporator coils behind the back panel of the freezer are icing up and blocking the flow of air it is an auto defrost failure.
check defrost heater, defrost thermostat.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If they are ok the problem is the pbm control, part 6 on your diagram.
http://www.appliancepartspros.com/sect/m/g/l/mglrm2rfis.gif
#3 Posted : Tuesday, April 14, 2009 3:09:55 AM(UTC)
When you say the condenser's pipe is frozen do you mean that in the compressor area under the fridge there is ice on one of the pipes leading out of the compressor before it enters the refrigeration compartment.
I think I saw something like this in a tech bulletin had something to do with a dryer problem.
Yefim
#4 Posted : Tuesday, April 14, 2009 4:06:15 AM(UTC)
Yefim
Hi. NO imean the condenser is inside refrigerator not a freezer. There is a drain that getting frozen and build ice under condenser. Thanks, Yefim.
woodchuckie
#5 Posted : Tuesday, April 14, 2009 6:36:25 AM(UTC)
woodchuckie
That is the evaporator inside. The condenser is outside. Anyway Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
Part 6 on this diagram is your drain. http://www.appliancepartspros.com/sect/i/5/z/i5z1r5fadk.gif
Electrolux Refrigerator not getting cold (Refrigerator & Freezer Repair)
by jesus freak 3/30/2024 1:11:55 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
Samsung Refrigerator - Service Kit for Icing Issue (Refrigerator & Freezer Repair)
by keith1386 3/24/2024 8:57:57 AM(UTC)
Automatic water filter bypass - Whirlpool Refrigerator GD5SHAXLQ02 (Refrigerator & Freezer Repair)
by z-vap 2/28/2024 2:08:23 PM(UTC)
Maytag Refrigerator freezing food on lowest setting (Refrigerator & Freezer Repair)
by ilgy 2/15/2024 8:14:17 AM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Power Surge damage to Refrigerator and Clothes Drier (Refrigerator & Freezer Repair)
by CBorucki 1/21/2024 7:29:43 AM(UTC)
Frigidaire Refrigerator model 253.56602402 issue (Refrigerator & Freezer Repair)
by anitak4242 1/17/2024 8:32:53 PM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire Refrigerator FRS24XGCB1 (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:18:22 PM(UTC)
refrigerator compressor clicking off (Refrigerator & Freezer Repair)
by rleescott 12/22/2023 4:57:43 AM(UTC)
