temp control digital light s dead only thing working is light bulb nothing else where do i chek first? mother board or tem control
Did you fix the problem? I have the same issue.
Originally Posted by: wapiwulo temp control digital light s dead only thing working is light bulb nothing else where do i chek first? mother board or tem control Did you find the problem? I have the same issue.
I just fixed the same model fridg. Checked for proper voltage to the board,then replaced the board WR55X10942
