Discuss
whirlpool refrigrerator defrost problem
 in
Refrigerator & Freezer Repair
The freezer is not defrosting properly, so the unit freezes up and causes the refrigerator not to cool. I'm
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » whirlpool refrigrerator defrost problem
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-02-2007, 12:19 PM
cookdd cookdd is offline
Junior Member
cookdd is on a distinguished road
Default whirlpool refrigrerator defrost problem
Model Number: et18dkxwn00   Brand: Whirlpool   Age: 5 - 10 years
The freezer is not defrosting properly, so the unit freezes up and causes the refrigerator not to cool. I'm not sure how to diagnose which part needs to be replaced.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-02-2007, 05:49 PM
Adam / APP Team Adam / APP Team is offline
Service Pro
APP Team
Adam / APP Team is on a distinguished road
Default
Dear cookdd,
( Caution ) Unplug the refrigerator.No power is needed for these tests.
The defrost system consists of three parts.
The timer, heater and thermostat.
Rule out the two before replacing the timer because the timer is a little more complex to advise on.
If you have an ohm meter set it at the lowest setting ( RX1 ) to check continuity on both the heater and the thermostat.
The heater should have continuity.
The thermostat will also have continuity when its frozen or at its coldest.
Be sure to isolate the parts by disconnecting the wires for accurate testing.
The heater and thermostat are located behind the back wall in the freezer section near the evaporator.
The timer is either in the control housing with the control that adjusts the temperature in the fresh food section or down on the bottom behind the kick plate.
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices.
Thank you for supporting our free repair help forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
defrost cycle problem blessen Refrigerator & Freezer Repair 2 07-29-2007 10:31 AM
GE Top frz defrost problem? vrocrider Refrigerator & Freezer Repair 1 07-21-2007 10:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
