If my water inlet valve works to my ice maker via hot-wiring it, does that mean the selinoid works and I should not worry about and think of other things like the ice maker thermostat?
If you tested your water valve and were able to get it to work by applying direct power to it, the valve does indeed work. What is the problem with your ice maker?
