My freezer is working, but the refrigerator is not cooling. The freezer had significant ice build up. I force defrosted the freezer following instructions on this site. Obviously that means the heater works. Does this then point to the defroster thermostat as the problem? I hate to cut the wires to the thermostat to test it, if the problem is likely elsewhere.
