Help Cooling Fan Only Works Sometimes Than Shuts Down I Have Replaced The T/stat, But No Help Freezer & Frig Are Ot Cooling Down
I would remove the evaporator fan motor and test in the wall outlet, if bad, order a new one AP3892525. To save money and if you are good on mechanical things, order a universal replacement AP4503254
Originally Posted by: richappy I would remove the evaporator fan motor and test in the wall outlet, if bad, order a new one AP3892525. To save money and if you are good on mechanical things, order a universal replacement AP4503254 the fan motor does work, i am thinik it may have something to do with the circut board, as the frig will run fine for about 3 hours, but when it goes into defrost mode it won't start back up. if i dis-connect the blower & then re-connect, it resets itself & runs for around 3 hours again, this appears to be the cycle.
Sure seems like a bad control board AP3964290, probably a bad driver on the board. Considering the high price, I would measure the current to the motor, if excessive, could burn out a new board.
