The fridge cooling fan is not working. I tried waiting 30 minutes and still it doesn't start. The back of the fridge is cold and the freezer works fine. The temp sensor seems to be OK. I removed the inside back panel to expose the coils and fan. The coils are cold (not frosted over). The fan is not iced over. I tested it with a meter and there is current flowing. I am assuming the fridge cooling fan needs replacement, but there is the control board... What other parts or electronic systems are linked to the fan that may need to be replaced, besides the obvious non-working fridge fan? The refrigerator keeps beeping every 2-3 minutes. I pressed both power cool buttons and I get Freezer:00, and Fridge: 0. don't know the code. Any suggestions about fixing this Samsung fridge or what parts to get? Thanks!
