Refrig water dispenser will flow with good pressure and then suddenly slow considerably. After hours of non use the pressure will return only to slow again after filling a glass or two. I replaced the water valve part # AP4081950 but the problem remains. The water pressure from the main line is good and unchanged. There is no restriction in the water line to the fridge. There are no lines freezing. The problem is the same with and without the water filter installed. I am at a loss on the solution. My thoughts are: 1) the new valve is bad. 2) the electronics supplying the voltage to the valve [FONT=Calibri","sans-serif] solenoid[/FONT] is bad. Appreciate your help
