the icemaker stopped working after a power failure(Irene). Water flows from dispenser, icemaker gets cold and motor pushes ejecting arms around but there is no water in the tray to freeze. I shut the refrigerator down for 20 minutes and restarted but no luck. Does the same water valve that supplies water to the door also supply water to the icemaker? It appears to be a two part valve? Thanks for the help.
