jhiggins111
#1 Posted : Saturday, April 11, 2009 11:35:47 AM(UTC)
jhiggins111
Fridge and freezer won't get cold....it runs/ fan runs and compressor runs, coil starts to get cold...a buddy who is an HVAC guy looked at it....says if compressor doen't feel "really hot" that he thinks its either the defrost timer or the temp control switch...found these parts and look very simple to swap out.
Any suggestions?
#2 Posted : Saturday, April 11, 2009 12:29:43 PM(UTC)
Replacement parts for FRG FRT18IL6DMJ | AppliancePartsPros.com
Here is the wiring diagram
ftp://ftp.electrolux-na.com/Pr...F/Anderson/240379018.pdf
From your description I do not think it is either
defrost timer - remove the rear covers at the back of the freezer so you can see the evaporator coils. If they are not heavily iced/frosted up you do not have a defrost problem.
temp control - unless the condenser/compressor fan is shutting off the compressor is getting voltage and it is trying to cool down to set point.
Sounds more like low freon. Check the evaporator coils if they only get cold/frosty where the freon enters the coil, it is probably low freon
Here is a good link
http://www.applianceaid.com/refrigerator.html
Check out #20 and the example pictures part way down the page
jhiggins111
#3 Posted : Saturday, April 11, 2009 2:37:11 PM(UTC)
jhiggins111
Yup, only cold coming out of compressor....
what is approx cost for appliance tech to add freon? Does this mean it's leaking freon ( 2 year old fridge)?
#4 Posted : Sunday, April 12, 2009 3:07:05 AM(UTC)
Sorry cannot help you with a cost.
Perhaps call a couple local repair shops for a quote.
If you post your location maybe one of the techs who posts on this site could give an estimate.
Yes you have a leak.
There is no use refilling it unless the leak is found and fixed first.
