Welcome Guest! To enable all features please Registers on the forum or Register.
acronin
#1 Posted : Saturday, April 11, 2009 9:55:54 AM(UTC)
acronin
Water keeps pooling up under the fruit drawers. It is leaking from somewhere, I cant find the location.
woodchuckie
#2 Posted : Saturday, April 11, 2009 11:28:45 AM(UTC)
woodchuckie
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
rubber hose conector decayed and leaking. (Dishwasher Repair)
by Guest 2/25/2024 3:33:37 PM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Water reservoir is leaking and freezing (Refrigerator & Freezer Repair)
by Guest 2/24/2024 12:38:19 PM(UTC)
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
GE GSD2200Z01AD Leaking out front bottom (Dishwasher Repair)
by jappel 1/22/2024 7:02:46 AM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Leaking outside of refrigerator (Refrigerator & Freezer Repair)
by Guest 10/11/2023 3:47:19 AM(UTC)
REFRIGERATOR IS LEAKING WATER (Refrigerator & Freezer Repair)
by Guest 8/9/2023 9:19:28 AM(UTC)
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 8/1/2023 8:16:28 AM(UTC)
