Americana side by side refrigerator with water and ice dispenser.
The water dispenser does not stop. If i turn off the water by the valve at the wall, the water stops. Then, I turn the water back on and no water comes out, good so far. I press the dispenser and the water flows, and when I let the dispenser go, the water keeps flowing.
I have tried to press the button to change it to ice, but the water still flows. The only way to stop it, is to shut off the valve at the wall.
what could it be?
