Discuss
Refrigerator good but freezer not cold enough
 in
Refrigerator & Freezer Repair
I have this small refrigerator out in the garage and and the refrigerator seems to work fine and stays between
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator good but freezer not cold enough
  #1 (permalink)
Old 11-28-2007, 11:14 PM
JoeP JoeP is offline
Junior Member
JoeP is on a distinguished road
Question Refrigerator good but freezer not cold enough
Model Number: GFR12AAMRWW   Brand: GE   Age: 5 - 10 years
I have this small refrigerator out in the garage and and the refrigerator seems to work fine and stays between 38 and 41 degrees but the freezer is at about 29 degrees and will not freeze food. This I think should be around 0 to 10 degrees. Where is the the temp sensor for this model and could this cause the problem? This refrigerator has always run very quiet and is hard to tell if things are running or not but I believe the fan is running and can feel the compressor run.
When I went out to get the model number I got a wild hair and took the cover off with the thermostat on the right side of the fridge where the door closes and hits the switch and everything there seems to be fine. I did notice that the compressor kicked on and the temp in the freezer dropped rapidly after I replaced the cover. Whats behind this cover that could cause the temperature to remain constant in the fridge and and keep the freezer warmer than it should? Thermostat? Door Switch? Something else?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-29-2007, 03:28 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
What's the average temperature in the garage?
__________________
  #3 (permalink)
Old 11-29-2007, 11:04 PM
Junior Member
Default
Currently about 40 degrees during the day and about 35 at night. The freezer did get to about -16 degrees when the compressor came on last night but tonight when I came home from work the temp was back up to +18 and currently is at 25 degrees. I did read on a british forum page before I found this one yesterday that the temperature in the garage may be causing this. Could this be the cause?
  #4 (permalink)
Old 11-29-2007, 11:07 PM
Junior Member
Default
This post was in error
  #5 (permalink)
Old 11-30-2007, 02:31 AM
Senior Expert
APP Volunteer
Default
The only way to fix this is replacing the cold control with a constant differential control (ambient control) Part # 3030-505 (26238).
__________________
  #6 (permalink)
Old 11-30-2007, 12:54 PM
Junior Member
Default
Is this because of the garage temperatures or is it a failure with the part. I have to ask because the part cost more then what I paid for the fridge.
  #7 (permalink)
Old 11-30-2007, 02:46 PM
Senior Expert
APP Volunteer
Default
Your present cold control will not perform at low ambient temperatures. Also, be aware, the low temperatures may damage the compressor and make it hard starting, oil tends to congeal at temperatures below say 35 degrees.
__________________
  #8 (permalink)
Old 11-30-2007, 08:28 PM
Junior Member
Default
So even if I change the cold control I still have the potential for more problems. I'll just move it into the house until I get my garage heater installed in January. Besides it gives me one more reason to tell my wife why I need the heater in the garage .
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Refrigerator is warm freezer is cold !! Steve705 Refrigerator & Freezer Repair 1 10-07-2007 01:24 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 03:58 AM
Freezer has frost and cold/frig is not very cold DinATL Refrigerator & Freezer Repair 1 09-14-2007 08:38 PM
Freezer cold, refrigerator cool barthayden Refrigerator & Freezer Repair 0 08-23-2007 05:43 PM
freezer fine, refrigerator not cold fargnoli Refrigerator & Freezer Repair 0 08-08-2007 10:24 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
