| » Ice Maker Not Working KitchenAid |
Quote:
No, they are not related. Sounds like the water inlet valve is the culprit. - The water inlet valve Part number: AP3160649 Gene. Ads By Google
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
__________________
Gene- I have Kitchen Aid, model # KSRP25FSSS01. Water dispenser works fine, no water going to icemaker. When I open the door and simulate it being close, that is I shut the flopper on the left and press the button at the top which turns the interior light off, the red sensor light goes out. Is this what should happen, or shold it always be flashing/solid?
I removed the icemaker and melted out the ice that was in it. What steps should I take to solve this? |
Quote:
If you would, please confirm you agree this means the motor must be replaced. Thanks. (This is annoying because our unit was purchased less than 2 years ago, and in fact the motor label states a mfg. date of 102609, about two weeks before we bought our unit!) |
ddsflagday,
Looks like you are on the right track. If the gears are not revolving then the motor most likely is the culprit. The manufacturer 2322580 part number is APP Part number: W10271506 Gene.
__________________
Quote:
Do it again, but don't touch the light switch. Make sure the water feeding tube into the ice maker is unclogged. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRP25FSSS01 REFRIGERATOR | AppliancePartsPros.com Gene.
__________________
The light sensor seems to be inconsistent. Sometimes it flashes correctly, sometimes there's no light at all. The tube leading into the icemaker seems to be clear. I manually added water into the icemaker, but it didnt trigger the cycle. If the optics are bad, does that mean the icemaker wont dump the ice even if filled manually? Thanks
Gene-
The light sensor seems to be inconsistent. Sometimes it flashes correctly, sometimes there's no light at all. The tube leading into the icemaker seems to be clear. I manually added water into the icemaker, but it didnt trigger the cycle. If the optics are bad, does that mean the icemaker wont dump the ice even if filled manually? Thanks Read more: Ice Maker Not Working KitchenAid http://forum.appliancepartspros.com |
Hello
this thread has answered most of my qustions about my failed KitchenAid model KSCS25INSS00 refrig's icemaker. Optics seem fine - 2 flashes when flapper open, led on steady when flapper closed. Apparently bad icemaker control module. My only concer before ordering a new icemaker is the fact that I do not get any voltage to the module. even unplugged, there is no voltage to the connect the icemaker hooks up to. Should that be a concern? thanks, Terry |
Terry,
Possible that the optic boards are bad too even there is no error code shown. Very likely that one of the power relays is faulty. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSCS25INSS00 REFRIGERATOR | AppliancePartsPros.com Gene.
__________________
| Display Modes | |
| Kitchenaid Ice Maker no working | lavellino | Refrigerator & Freezer Repair | 1 | 10-23-2009 12:35 PM |
| kitchenAid ice maker not working | sambino69 | Refrigerator & Freezer Repair | 0 | 10-07-2009 05:57 PM |
| KitchenAid Ice Maker Not Working | Brian John | Refrigerator & Freezer Repair | 1 | 07-28-2009 04:22 PM |
| KitchenAid Ice Maker not working | jkcpa | Refrigerator & Freezer Repair | 0 | 06-03-2009 09:55 PM |
| Ice Maker Not Working - KitchenAid | mames | Refrigerator & Freezer Repair | 0 | 04-13-2009 09:55 AM |
