Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Did you check the black wire for continuity? This wire has inline thermal fuse and, if it was open that's
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #61 (permalink)
Old 08-01-2011, 01:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This wire has inline thermal fuse and, if it was open that's why the ice maker did not work.
Anyway, it's up and running and it is good news.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #62 (permalink)
Old 08-04-2011, 01:34 PM
Junior Member
carlrose is on a distinguished road
Default
I have a Kenmore Elite model 56532400 with the same problem of no ice the rest in this thread have. I see no LED light at any time. Should I see it with this model? The circuit board which is 4389102 appears similar as does the ice maker module itself.
  #63 (permalink)
Old 08-04-2011, 03:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by carlrose View Post
...I see no LED light at any time. Should I see it with this model?...
The answer is: yes. You should see the LED as soon as you open the freezer door. If it's not there, replace the optic PC boards.
__________________
  #64 (permalink)
Old 08-20-2011, 11:46 AM
Junior Member
electric45mike is on a distinguished road
Default
Gene- Have a KitchenAid KSRA25FKSS00 ice maker that won't fill. Temp is 2 deg., fill tube is clear, red LED stays solid when flapper closed. I have continuity in black wire. Checked for 120VAC between N & L & don't get any voltage. Jumped T & H & got no movement. Attempted to check input voltage to icemaker but only get 54 vac. Which wires should carry the 120 to icemaker? Thanks, Mike
  #65 (permalink)
Old 08-20-2011, 04:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Try to do the following test:
1. Jump test points “T” to “H”.
2. Make sure the ice bin is on the door, the IDI slide is “on,” and both doors are closed.
3. Unplug the unit, or turn off the power for 10 seconds, and then reapply power (it's better if the compressor is not running at that time).
4. After 10 seconds, open and close the freezer door.
5. After 15 seconds, open the freezer door. The ice maker should be running.
6. Remove the jumper from test points “T” to “H”.
Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRA25FKSS00 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
__________________
  #66 (permalink)
Old 08-20-2011, 04:59 PM
Junior Member
Jerry Cave is on a distinguished road
Default
Kitchenaide ice maker not workiing ... getting water, frozen in bottom of maker, LED flashes twice, then twice, then twice.
  #67 (permalink)
Old 08-20-2011, 05:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the refrigerator?
How did you test the LED?
__________________
  #68 (permalink)
Old 08-20-2011, 07:07 PM
Junior Member
Default
Gene,
Executed the above procedure & it is making ice! Still have to replace water valve because of fill line freezing but don't need ice maker yet. As usual, you are amazing Gene. Thanks alot.
Mike
  #69 (permalink)
Old 08-24-2011, 02:37 PM
Junior Member
Default Ice maker now working.
Gene,
On 8/4 you replied to me about the led not showing on my ice maker. I replaced the two modules and the correct led sequences showed. I initiated one cycle by a manual fill of the tray but after ejecting the ice the tray did not refill. I discovered that the inlet tube had an ice plug which I removed. All seems to be working correctly now. I do not know if the bad modules and the ice plug were somehow related, or if the plug developed on its own during the time the circuits were bad. I appreciate the good advice that you gave. Thank you.
Carl
  #70 (permalink)
Old 08-24-2011, 07:30 PM
Junior Member
ddsflagday is on a distinguished road
Default Ice Maker makes and ice, motor runs, but won't dispense
Gene, our 3-year-old Kitchenaid KSRV22FVSS makes ice, dumps it into the bin, but when one presses the outside lever to get ice none dispenses. The motor can be heard, but the augur does not turn. Any suggestions as to what part may be bad? The water side works fine.
Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
