Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Originally Posted by Gene Steve, Sounds like the problem is some where in the ice maker control module. You can
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #41 (permalink)
Old 06-28-2011, 12:36 AM
Junior Member
steve.w is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Steve,
Sounds like the problem is some where in the ice maker control module. You can try to replace it but I would suggest to replace the whole ice maker. The difference in price is just about $10, but the rate of success on ice makers repairs is very low. So, the whole new ice maker will make the repair much more reliable.
- The ice maker Part number: AP4360346
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRS25CHSS00 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
Gene,
Thanks for your advice. I think that's what I'll do. Based on the replacement parts diagram that you pointed me to for my model, I think that the ice maker part number that I need is AP2984633, not AP4360346.
Thanks again!
  #42 (permalink)
Old 06-28-2011, 01:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Steve,
These two ice makers are identical. The difference between them is: the ice maker with the part number AP4360346 contains the ice maker only. So, you have to use the head cover and shut off arm from the old one. The other ice maker comes as a kit with all accessories.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #43 (permalink)
Old 06-29-2011, 10:28 PM
Junior Member
KevinJ123 is on a distinguished road
Default
Kevin,
Looks like you are on the right track with new optic.
For the ice maker: I'm afraid you could damage something during the module replacement. You'll see it after you replaced the optic boards.
- The optic PC board kit Part number: AP3137510
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GC5SHEXNS00 REFRIGERATOR | AppliancePartsPros.com
Problem fixed!!
Replaced the optics PC board today and already have ice. THANKS!
Kevin
  #44 (permalink)
Old 06-30-2011, 01:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Kevin. I'm glad it's up and running.
__________________
  #45 (permalink)
Old 07-01-2011, 08:26 AM
Junior Member
MARKY is on a distinguished road
Default Joining the broken Ice Maker Team.....
Hey guys - I have the same problem as you, but wanted to confirm which part I should replace before going forward.
Background;
Whirlpool side by side. Model # GS6SHAXKB01
Door dispenses water.
No water to ice maker, found frozen water in tube to ice maker and cleared it.
Did following tests;
"N" & "L" - ok reads 120 V.
"T" & "N" - nothing happens.
"L" & "V" - no water dispensed.
"M" & "N" - nothing happens.
"H" & "N" - no heat.
So do I need to replace the entire Ice Maker? If so what is the part number (can't find it for complete unit).
Is the water dispensing valve OK?
Thanks in advance for you help!!
Mark
  #46 (permalink)
Old 07-01-2011, 04:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mark,
Did you try to short points "T" & "H"? Make sure the wire is at least 1/2" in.
Did you check the status LED on the right side in the freezer?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GS6SHAXKB01 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
__________________
  #47 (permalink)
Old 07-01-2011, 07:56 PM
Junior Member
Default Up and Running Again!!
Gene;
Thanks for your quick reply - always a pleasure to work with you, you have helped me several times in the past...
Sorry, I miss typed, I did the "T" & "H" short and nothing happened. I reassembled the IM , put it back in the freezer and let the freezer section cool down. After the freezer cooled down I turned the IM On and now about 8 hours later its making ice again!! Not sure what to make of this, its hard to believe a frozen water feed line would cause this? All is working well at the moment (in fact I just heard it dump another load of ice and refill with water) so unless something goes wrong in the next 24 hours Ill assume it was the frozen water line that caused all the problems.
Again, thanks for all your support!!
  #48 (permalink)
Old 07-03-2011, 04:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Mark. If the water line will freeze up again, I would suspect the water inlet valve.
__________________
  #49 (permalink)
Old 07-17-2011, 10:02 AM
Junior Member
mechanicallydmb is on a distinguished road
Default emitter light not working on ice maker
Hi Gene,
I have a Kitchen Aid side-by-side, model KSRA22ILSS00. The ice maker stopped producing ice - the emitter light is off. I turned the power off for ten minutes and the emitter light did not flash or show any color when turned back on. The icemaker was turned off and then turned back on. I do have water flowing through on the outside door. Should I check for 120VAC at the "L" and "N" test points as you suggested or just replace the whole unit? Or just replace the optic PC board kit? I think you said the difference in price was minimal so I'd rather replace the unit if that will rule out any other issues. I have not tried the hairdryer on the hose as yet.
Thanks!
Alan
  #50 (permalink)
Old 07-18-2011, 03:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Alan,
If the LED is off while the freezer door is open and the light inside the freezer is on, then the optic boards are bad. No doubt about it. You can not check the rest until you replace them.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRA22ILSS00 REFRIGERATOR | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
