Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
I have a similar issue to the other folks in this thread. Water dispenses fine. Ice maker makes ice sporaticlly,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #21 (permalink)
Old 06-08-2011, 01:33 AM
Junior Member
nschwaber is on a distinguished road
Default ice maker problem - KSRG25FKSS15
Water dispenses fine. Ice maker makes ice sporaticlly, maybe once or twice a day. When I close the emmiter door I have no red LED. If I close the door switch at the top of the freezer the LED starts blinking.
Thanks,
Nathan
Ads By Google
  #22 (permalink)
Old 06-08-2011, 01:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Nathan,
What is the exact measured temperature in the freezer?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRG25FKSS15 REFRIGERATOR | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #23 (permalink)
Old 06-08-2011, 09:44 PM
Junior Member
Default
Thanks for the reply Gene -
It seems that the temperature would be a simple thing to get, however modenr houshold thermomethers both mercury and digital don't go below 90 degrees.
Any suggestions?
Nathan
  #24 (permalink)
Old 06-08-2011, 10:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Nathan,
I'm afraid there is much more serious problem than not working ice maker. Looks like your refrigerator is not cooling properly. 90°F is warmer than the temperature in the kitchen. You have to call a certified tech to check the sealed system.
__________________
  #25 (permalink)
Old 06-08-2011, 10:15 PM
Junior Member
Default
Sorry Gene... I think you miss-understood my reply. My freezer is not 90 degrees, infact it's quite cold. I was mearly saying that the generic household thermometers (the kind you use when your sick) don't register below 90 degrees.
So with that I was unable to answer your original question of how cold is the freezer. Other than saying everything in there is frozen properly I can't get an exact reading.
Nathan
  #26 (permalink)
Old 06-11-2011, 07:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sorry for this misunderstanding.
Looks like you have to buy a special refrigerator thermometer. They usually priced bellow $10 and you can find them at many stores.
__________________
  #27 (permalink)
Old 06-11-2011, 10:31 PM
Junior Member
kfinitz is on a distinguished road
Default KitchenAid Icemaker not working either
Similar problem here too! I have a KitchenAid side by side KSRA25ILSS03 and my ice maker stopped working all the sudden. The ice in the door works fine and I can put already made ice in the dispenser and it will dispense it from the door. When I manually close the flap on the left side the sensor light stays solid red but when I release the flap the red lite blinks twice and then off, twice and then off, twice and then off... Any ideas?
  #28 (permalink)
Old 06-13-2011, 02:50 AM
Junior Member
melaniel is on a distinguished road
Default
I have a siimilar problem as well. I have a Kitchenaid refrigerator that the icemaker has quit working. When I open the door the LED flashes twice. When i close the flap on the left the LED on the right stays on. When I simulate the door closing the light goes off. Is this a bad icemaker? MOdel no. KSRW25CRSS01
Read more: Ice Maker not working
http://forum.appliancepartspros.com
  #29 (permalink)
Old 06-13-2011, 05:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Remove the ice maker (the instructions are attached) but do not disconnect the wire harness. Check the water feeding tube for any icicles or frost inside.
If there are any, defrost it using a hair dryer.
If it is clear, remove the ice maker head cover and check for 120 VAC between the "L" & "N" test points. Make sure the test probes go in at least 1/2".
Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRA25ILSS03 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
File Type: doc Removing the ice maker - in door ice system 2.doc (522.0 KB, 129 views)
__________________
  #30 (permalink)
Old 06-13-2011, 05:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
You can use the same instructions as I posted for kfinitz.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRW25CRSS01 REFRIGERATOR | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
