Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Hi, They seem to be a little bit longer than they used to be. Jewels74
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #211 (permalink)
Old 04-16-2013, 02:44 PM
Junior Member
jewels74 is on a distinguished road
Default ice cubes
Jewels74
  #212 (permalink)
Old 04-16-2013, 05:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Looks like the ice maker itself is bad.
- The ice maker Part number: 2198597
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #213 (permalink)
Old 04-19-2013, 04:57 AM
Junior Member
aj60467 is on a distinguished road
Default
Hi Gene
My refridgerator is model KSCS25INSS00 and there's ice in the tray but does not dispense to bin as of yesterday. I looked at the flashing light on the right and it flashes twice then pause twice pause pattern with 'door' open or closed. Does that mean it needs a new PC board? If so are there specific instructions on how to change?
Thank you
  #214 (permalink)
Old 04-19-2013, 01:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by aj60467 View Post
Hi Gene
Thank you
Hello,
Perform the troubleshooting as instructed in the attached file and post the results.
File Type: doc In door ice system - component diagnostics.doc (167.0 KB, 67 views)
__________________
  #215 (permalink)
Old 05-11-2013, 06:01 PM
Junior Member
DetDB is on a distinguished road
Default Emitter board
Where is the emitter board located. The IDE maker led light flashes twice, even when the door simulator is pushed in. I believe the emitter board is the culprit. Is this a correct assumption.
  #216 (permalink)
Old 05-13-2013, 08:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
What is the complete model number of the refrigerator?
__________________
  #217 (permalink)
Old 05-30-2013, 04:53 PM
Junior Member
cajunyota is on a distinguished road
Default
Gene, I hate to beat a dead horse with this and I am sure that this is a continuous question/issue that people bring up to you. I've read through the forum on the ice maker issue and looked through the trouble shooting guide that you've posted, however, I am unclear on what to do/how to figure out what may be wrong. Anyhow, I have a KitchenAid refrigerator, Model # KSCS25INSS00, Serial # SR4841204, MFG Date: 12-04. The freezer was spewing water all over the inside and leaking out on the floor, turned off the water supple and the ice maker switch on the inside, right side of the freezer. I later turned the water supply and ice maker switch back to on, yet no ice was dispenced from the maker into the door container. I removed the ice maker and there is ice in the maker, but it is not ejecting. There was a minimal amount of frost in the water feeder tube that feeds the ice maker. When the freezer door is open, the LED pulses twice, when i depress the flapper on the left inside of the freezer, the LED becomes solid. I checked voltage between L and N on the ice maker and got nothing, disconnected the connector to the ice maker and voltage between line and neutral on the connector only showed about 90VAC. What further troubleshooting steps can I take to figure this out? Thanks.
  #218 (permalink)
Old 07-09-2013, 10:04 PM
Junior Member
robh1 is on a distinguished road
Default Low voltage at wiring harness
Similar to post above, I have no voltage between L & N which if I'm following this thread correctly seems like a bad icemaker.
But at the wiring harness, I only get about 35 VAC between black and white. Does that imply that there is a bigger problem somewhere deep inside the fridge electronics?
Thanks,
Rob
  #219 (permalink)
Old 07-11-2013, 01:17 PM
Junior Member
rbkean is on a distinguished road
Default ice maker not working
Not sure if I'm entering this forum correctly but have same problem n appreciate any help/guidance/recommendation. Kitchen aid KSBS25INBLOO with ice maker #2198597 stopped making ice. Watched videos n checked all I could. Everything "seems" ok ---no corrosion on any copper electrical connections etc---no mold buildup--orange/red light flashes and goes steady as appropriate----ejector arms in up position but no water enters/flows into mold chamber. Don't know if need new ice maker unit or water flow valve---or whatever. Any thoughts/recommendations appreciated. Thx much!
Bob
  #220 (permalink)
Old 02-09-2014, 10:05 AM
Junior Member
jhayden017 is on a distinguished road
Default KitchenAid ice maker not working
Hi Gene, where can I find the wiring diagram to test the ice maker? I have a KitchenAid KSCS25FVSS01
The LED blinks twice with the door open, simulate door closed and the LED goes out, close the flapper on the left and no change, no water going into the ice maker, water on the door is fine, filter is fine, freezer is 0 degrees and ice maker is in ON position. Thanks you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
