Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Gene, My model # is ED5LHAXMQ10. After replacing the dual solenoid, I noticed that I have no infered beam when
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #11 (permalink)
Old 04-29-2009, 08:55 AM
Junior Member
markz404 is on a distinguished road
Default
Gene, My model # is ED5LHAXMQ10. After replacing the dual solenoid, I noticed that I have no infered beam when I simulate a closed door. I ordered and replaced both receiver and emitter and still no beam. Any ideas? Thanks Mark
Ads By Google
  #12 (permalink)
Old 04-29-2009, 12:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by markz404 View Post
...I have no infered beam when I simulate a closed door...
Hi Mark,
Can you explain more specifically how did you do this test?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 08-30-2009, 03:25 PM
Junior Member
Redstaines is on a distinguished road
Default
Gene,
I also have a similar ice-maker issue. When I close the flapper door, there is no LED light at all. I tried filling the tray manually - it then freezes and empties the ice out eventually, but does not refill.
Our model # is KSRS25IKSS01.
Any suggestions? The water works fine in the door..........
  #14 (permalink)
Old 09-13-2010, 10:46 PM
Junior Member
bob w58 is on a distinguished road
Default
I have a similar problem. When I open the door the red light flashes a blinking light. I have checked the water filler tube & it is not clogged. It is model KRSI25FNBL00. The dispenser sends out the ice left in the hopper but it is almost empty. A new water filter did not help.
  #15 (permalink)
Old 12-09-2010, 03:21 PM
Junior Member
David B is on a distinguished road
Default Kscs25inss00 Stoped Working Please Help
Gene,
If the flopper is shut and the status LED is still flashing on the right side and the ice maker still isn't working. Then what?
That was stopped with two p's.
Quote:
Originally Posted by Gene View Post
According to your description looks like the ice maker has gone bad, but I would check the optics first to make sure there is nothing wrong.
Open the freezer door, close the flopper on the left side and watch the status LED on the right side. If the LED stays "on" then the ice maker is the culprit.
- The part number for the ice maker is AP3182733
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSCS25INSS00 | AppliancePartsPros.com
  #16 (permalink)
Old 12-10-2010, 05:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by David B View Post
...If the flopper is shut and the status LED is still flashing on the right side and the ice maker still isn't working. Then what?...
David,
Then a new optic PC board kit should fix it.
- The PC board kit Part number: AP3137510
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSCS25INSS00 REFRIGERATOR | AppliancePartsPros.com
__________________
  #17 (permalink)
Old 12-16-2010, 09:08 PM
Junior Member
Default
David,
Where is that part located? Which diagram?
Thank you,
David B
  #18 (permalink)
Old 12-16-2010, 09:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
They are located in the freezer on both sides of the frame (#26 & #38 on the diagram).
__________________
  #19 (permalink)
Old 12-23-2010, 05:48 PM
Junior Member
ajf009 is on a distinguished road
Default
Gene, I have the same problem as water comes out water dispenser on door ok but not dispensing water for filling trays on freezer side. I manually closed flapper door on left side and sensor light stops blinking and stays solid red, is this correct ? I have a KitchenAid model KSSC48QMS01
  #20 (permalink)
Old 12-24-2010, 05:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Make sure the temperature in the freezer is bellow 10°F and the "on-off" switch on the right side is on.
Pull the ice maker out (the instructions are attached) but do not disconnect the wire harness.
Remove the ice maker head cover and check for 120VAC between "N" & "L" test points. Make sure the test probes are 1/2" in.
If there is 120VAC then using an insulated piece of wire (14 GA), short points "T" & "H" to run the motor. Leave the jumper in for a half of a revolution and remove it. The water valve should be energized in the last half of the revolution.
Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSSC48QMS01 48`` BUILT IN REFRIGERATOR | AppliancePartsPros.com
Read more: Water to ice maker quit working
http://forum.appliancepartspros.com
File Type: doc In-door ice system - Removing the ice maker.doc (627.0 KB, 145 views)
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
