Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Hi Gene, I can't believe so many things can cause the icemaker to stop working...the first I've seen in this
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #181 (permalink)
Old 01-31-2013, 07:36 PM
Junior Member
rrnworks is on a distinguished road
Default
Hi Gene,
I can't believe so many things can cause the icemaker to stop working...the first I've seen in this entire post that replacing the optics, valve, and/or icemaker hasn't worked. Anyway, I turned the freezer temp lever from 3 down to 1 but the temperature has not changed. Any ideas?
Thanks,
Chris
  #182 (permalink)
Old 02-01-2013, 01:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Chris,
Normally it takes about 24 hours to see any changes after adjustment.
How did you measure the temperature? Don't rely on digital display if there is one.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #183 (permalink)
Old 02-01-2013, 02:24 PM
Junior Member
Default
I'm using a regular analog freezer thermometer from home depot. It has been a couple days since the temperature was adjusted. Maybe a tad warmer at -12 degrees - still no ice.
  #184 (permalink)
Old 02-01-2013, 02:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Try to raise it to at least -5F. What is the temperature in the refrigerator?
__________________
  #185 (permalink)
Old 02-02-2013, 09:12 AM
Junior Member
Default
Fridge is 38 degrees (temp control on 2). I have the freezer temp control all the way down to 1.
  #186 (permalink)
Old 02-09-2013, 12:37 PM
Junior Member
mcdbones is on a distinguished road
Default
Gene,
*I have kitchenaid superba model#KSCS25INSS00
*Water flows from door but no ice
*Sensor does 2 blinks pause 2 blinks, when flap closed it's solid red
*I have tried testing voltage between N&L = ~35V
*Tried jumping H&T = completed about 1 revolution, water never activated
*Tried jumping again. now doesn't move & N&L = 0V
*Inlet valve not blocked or frozen
*Freezer was at 0-5 deg when started messing. now at 20 deg
*I'm wondering if having fridge hooked up to rev osm filter under sink would effect performance although we've had it that way in old house and worked fine.
I tried looking through most of these posts and entering as much info as I can to save you time. I really appreciate all the info you've given to others and any you can give me.
I will be ordering new ice maker regardless because coating on this one is chipping off and looks gross. I just want to make sure there's nothing else I should be ordering.
  #187 (permalink)
Old 02-09-2013, 04:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You may want to replace the ice maker first and see how it will perform. Post the results.
- The ice maker Part number: 2198597
Here are the breakdown diagrams and Parts for Whirlpool KSCS25INSS00 Refrigerator - AppliancePartsPros.com
__________________
  #188 (permalink)
Old 02-14-2013, 03:12 PM
Junior Member
Default
replaced ice maker yesterday. today=no ice
Tested fill tube the other day when I first asked question and I could blow through it so I don't think it's frozen.
Wife sick of buying ice at store. I think the best valentines present I could give her is a working ice machine.
  #189 (permalink)
Old 02-14-2013, 03:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Perform the diagnosis as described in the attached file and post the results.
File Type: doc In door ice system - component diagnostics.doc (167.0 KB, 23 views)
__________________
  #190 (permalink)
Old 02-16-2013, 05:49 PM
Junior Member
Default
performed test. jumped H&T with 14G wire. Nothing happened.
did LED code test.
First time: steady light for 5 seconds
2nd, 3rd, 4th times:3 pulses
my freezer doesn't have bail arm lever, just a switch to slide "on - off"
don't know how to check circuits
components looks fine
feezer reading ~20 deg. so maybe it just needs to get back down to under 12deg?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
