Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Hello Gene. I have a 5 year old model KSRL25FRST04 fridge. Just shy of owning it a year, the dispenser
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #171 (permalink)
Old 12-03-2012, 02:52 PM
Junior Member
reneeknight is on a distinguished road
Default Maker doesn't dispense ice
Hello Gene.
I have a 5 year old model KSRL25FRST04 fridge. Just shy of owning it a year, the dispenser motor had to be replaced. Several months ago, the dispenser again stopped working. It still does a terrific job of producing ice. If I empty the ice bin and ensure the path is clear, the dispenser will work once or twice, and then stop dispensing again. It SOUNDS like it's trying to work, but nothing comes out.
Any help you can offer is greatly appreciated!
Thank you.
Ads By Google
  #172 (permalink)
Old 12-03-2012, 04:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Remove the ice bin and check the coupling (#16 at the diagram). Ifthere is nothing wrong, remove the motor and test it as described in the attached file.
- The coupling Part number: 2188918
- The motor Part number: W10271510
Here are the breakdown diagrams and Parts for Whirlpool KSRL25FRST04 Refrigerator - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #173 (permalink)
Old 12-04-2012, 02:56 PM
Junior Member
Default
Thanks a zillion, Gene. I'll do that tonight. Will I be able to tell straight away if it's the coupling? Will it be obviously cracked or broken, somehow?
  #174 (permalink)
Old 12-04-2012, 04:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, you should see it.
__________________
  #175 (permalink)
Old 01-27-2013, 09:17 AM
Junior Member
rrnworks is on a distinguished road
Default
I've replaced the optics board and the ice maker but still no ice. The optics work as described (solid red light when flap is closed). I get water when I jumper the correct two on the ice maker. I also manually filled the ice tray but ice is never ejected. The ice maker is getting power. So I'm at a loss on what else it could possibly be except a bad replacement ice maker?
  #176 (permalink)
Old 01-28-2013, 08:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by rrnworks View Post
...I also manually filled the ice tray but ice is never ejected...
Hello,
Did the ice freeze?
What is the exact measured temperature in the freezer?
What is the complete model number of the refrigerator?
What is the part number of the ice maker you installed?
__________________
  #177 (permalink)
Old 01-29-2013, 10:09 PM
Junior Member
Default
Hi Gene,
Ice is frozen solid. Temperature is saying -15 degrees Farenheit. Fridge is a kitchenaid KSRG25FKSS17. Ice maker is 2198597 - it appears to be the correct replacement.
Thanks,
Chris
  #178 (permalink)
Old 01-30-2013, 03:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Chris,
-15°F is to low for the ice maker to work properly. The normal ambient temperature for the ice maker is 0°F. You have to adjust the settings for the freezer temperature.
Here are the breakdown diagrams and Parts for Whirlpool KSRG25FKSS17 Refrigerator - AppliancePartsPros.com
__________________
  #179 (permalink)
Old 01-30-2013, 04:48 PM
Junior Member
Default
Wow - ok. I've seen it go to 0 degrees, but when then compressor is running it chills to -15. What is the temp variance for the icemaker? I've seen we don't want it warmer then 0 but would -5 be ok?
  #180 (permalink)
Old 01-30-2013, 09:16 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The normal temperature range is -2°F to 5°F.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
