Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Originally Posted by amp0 I have a KitchenAid KSRK22ILSS02. The ice maker does nothing. I jumpered the T and H
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #161 (permalink)
Old 09-27-2012, 11:49 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by amp0 View Post
I have a KitchenAid KSRK22ILSS02. The ice maker does nothing. I jumpered the T and H points and the motor does not move and the tray does not heat up. I verified 115V at the ice maker connector and I verified continuity in the wiring harness.
I replaced the motor module (W10190935) but the results are the same. Any ideas on what to try next?
Thanks!
Open the freezer door. Make sure the on-off switch on the right side is on. Push in the flipper on the left side and watch the status LED on the right side. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRK22ILSS02 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #162 (permalink)
Old 09-27-2012, 12:56 PM
Junior Member
Jonah5 is on a distinguished road
Default
Kitchen fridge: kenmore elite 106.53709201
Garage: whirlpool ec3jhaxrs01
  #163 (permalink)
Old 09-27-2012, 01:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Perform the test as described in the attached file and post the results.
File Type: doc In door ice system - component diagnostics.doc (167.0 KB, 16 views)
__________________
  #164 (permalink)
Old 09-27-2012, 03:43 PM
Junior Member
amp0 is on a distinguished road
Default
Sorry, I forgot to mention I did the optical diagnostics and it was OK. With the flipper NOT pushed in I get the 2 pulses. With it pushed in the LED is on solid.
  #165 (permalink)
Old 09-27-2012, 07:52 PM
Junior Member
Default
Hi Gene. Performed the diagnostic test but couldn't get a harvest to initiate. Checked voltage of IM and it was normal. Replaced the garage IM with the original, same results: no harvest, normal voltage getting through. I also tried the other jumper tests and couldn't get a response on either ice maker. Any ideas? I know that the garage IM works, but all tests so far have been without response. Any chance the optics are bad?
  #166 (permalink)
Old 09-27-2012, 08:33 PM
Junior Member
Default
Well, after all that testing, with both IMs, I realized that this whole time the bale switch was in the OFF position! Sheeeesh! Anyway, redid test with the replacement IM (garage) and yes, the harvest initiated, finished and water dispensed. Checked lighting pattern, and only heard 3 beeps, but no light. Ran out of time, so for now I put it all back together and hope that the bale switch was the culprit for the garage IM not working.. If still no ice, I'll be back to try to diagnose some more. Thanks so far for your help, Gene!
  #167 (permalink)
Old 09-28-2012, 07:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Run the test as described in the previously posted attachment. Post the results.
__________________
  #168 (permalink)
Old 09-28-2012, 07:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Jonah. This switch off is also very common with brand new ice makers. Hopefully it will fix the problem.
__________________
  #169 (permalink)
Old 09-28-2012, 08:19 PM
Junior Member
Default
Hi Gene,
The results of the component diagnostics test are in my original post. With the T and H points jumpered, the motor does not run and the tray does not heat up. Looking for ideas on what to try next.
Thanks,
Andy
  #170 (permalink)
Old 09-29-2012, 05:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Andy,
I would recommend to replace the whole ice maker because it will make the repair much more reliable due to very low rate of successful ice maker repairs.
- The ice maker Part number: W10190961
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
