Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
My icemaker is making ice--however, the ice bin is full of ice that has melted/fused together. It is as if
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #131 (permalink)
Old 08-15-2012, 01:05 PM
Junior Member
rtabing is on a distinguished road
Default KitchenAid Model #KSCS25FKSS01 icemaker problem
My icemaker is making ice--however, the ice bin is full of ice that has melted/fused together. It is as if the ice was only partially solidified or somehow, water is also getting into the bin.
Any suggestions?
  #132 (permalink)
Old 08-15-2012, 01:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Any suggestions?
What is the exact measured temperature in the freezer?
Can you see any icicles around the ice maker or between the ice maker and the ice bin?
Here are the breakdown diagrams and Replacement parts for Whirlpool KSCS25FKSS01 REFRIGERATOR | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #133 (permalink)
Old 08-18-2012, 01:43 PM
Junior Member
fullysane is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
According to your description looks like the ice maker has gone bad, but I would check the optics first to make sure there is nothing wrong.
Open the freezer door, close the flopper on the left side and watch the status LED on the right side. If the LED stays "on" then the ice maker is the culprit.
- The part number for the ice maker is AP3182733
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSCS25INSS00 | AppliancePartsPros.com
I have the same model kscs25ins00 and not making ice as well.The LED is still blinking (not stays "on") when the left side flopper is closed. according to this video KITCHEN AID / WHIRLPOOL / KENMORE INFRARED ICEMAKER REPAIR - YouTube, the problem is the emitter board and sensor. Is this correct?
  #134 (permalink)
Old 08-19-2012, 09:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes. Most likely this is the culprit.
- The optic boards kit Part number: 4389102
__________________
  #135 (permalink)
Old 09-09-2012, 08:37 PM
Junior Member
Utejohn98 is on a distinguished road
Default KSCS25INBL01 ice maker not working
My Ice maker stopped working. When i open the door the LEd flashes twice. when I close the flipper it goes solid red. When I checked the voltage between N and L i got 106 volts. When i jumpered T and H I heard a click and nothing happened. I then checked the voltage between N and L and got zero. any ideas?
  #136 (permalink)
Old 09-10-2012, 02:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Try to do it by following the attached instructions. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool KSCS25INBL01 REFRIGERATOR | AppliancePartsPros.com
__________________
  #137 (permalink)
Old 09-10-2012, 06:11 PM
Junior Member
Default
I did this and nothing happened.
  #138 (permalink)
Old 09-10-2012, 06:18 PM
Junior Member
Default
Quote:
Ok now I am confused. I pulled it out to check the voltage and it started a cycle. I heard the same click that I heard last night and it made one batch of ice. I thought it was working when it made the ice last night. so the motor is working if it makes ice. does this mean that the control board is not working?
  #139 (permalink)
Old 09-10-2012, 06:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unplug the ice maker wire harness and check the voltage between the black and the white wires at the plug,
__________________
  #140 (permalink)
Old 09-10-2012, 06:39 PM
Junior Member
Default
it has 106.5 volts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
