Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Originally Posted by Gene Pull the refrigerator out of the wall. Remove the cover and make sure the compressor is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #121 (permalink)
Old 05-31-2012, 07:16 AM
Junior Member
jhn0002 is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Pull the refrigerator out of the wall. Remove the cover and make sure the compressor is running. You have to feel some vibration on a touch. Also check it's temperature. Post the results.
It's also a good time to clean the condenser.
Here are the breakdown diagrams and Replacement parts for Whirlpool GC3SHEXNS00 REFRIGERATOR | AppliancePartsPros.com
It seems to be the inverter that is shot. I'm going to install a new one and see if that will stand the compressor.
  #122 (permalink)
Old 06-21-2012, 07:50 AM
Junior Member
sdginz is on a distinguished road
Default Kitchen Aid KSRG25FKBL03
I have the aboove model kitchen aid side by side that recently quit making ice.
I have checked the optics by simulating a closed door and that appears to be working correctly from what I have read in the previous posts.
It does dispense water thru the door and ice if filled manually. I have also checked for blockage in the filling tube and found none. The ice maker never calls for water.
I have rotated the fingers of the ice maker manually and can hear it click but it never turns on its own.
Any ideas?
  #123 (permalink)
Old 06-21-2012, 01:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Swap the wires between the water valve solenoids. Push the water dispenser lever for a few seconds and check for water inside the ice maker.
If there is some water, replace the ice maker.
If there is no water, replace the water inlet valve.
- The ice maker Part number: 2198597
- The water inlet valve Part number: W10408179
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRG25FKBL03 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #124 (permalink)
Old 06-21-2012, 01:38 PM
Junior Member
Default
Quote:
Originally Posted by jhn0002 View Post
It seems to be the inverter that is shot. I'm going to install a new one and see if that will start the compressor.
I installed the new inverter and the compressor started right up. 24 hrs later, my fridge was cold and ice was in the ice maker. Has been working great ever sense.
Thanks for your help!
  #125 (permalink)
Old 06-21-2012, 01:39 PM
Junior Member
Default
Gene thanks for your quick reply.
Can you describe for me how to swap the wires between the water valve solenoids?
Where are they located? So what your saying is that when swapped the water dispenser will trigger water flow into the ice maker. Correct?
  #126 (permalink)
Old 06-21-2012, 01:57 PM
Junior Member
Default
Gene one additional question.
If I do need to replace the icemaker what is the difference between the part here on appliance pro's website versus one sold on Filter Fast for substantially less money.
Thanks.
  #127 (permalink)
Old 06-21-2012, 03:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad it's up and running.
__________________
  #128 (permalink)
Old 06-21-2012, 03:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The water valve is located on the back of the refrigerator. It has two solenoids: one for the ice maker and the other one for the water dispenser. Each of them has 2 wires connected to. By swapping the wires, the power from the water dispenser lever will come and energize the ice maker solenoid. If this solenoid is good and there is nothing with the water line to the ice maker, water should come into the ice maker.
About any other web site who may sell the same parts - did you check their return policy? 15% restocking fee and only 30 days for only unused parts? What are you going to do if your diagnosis was wrong and you would like to return the ice maker which you already installed?
Their price looks so suspicious, I would not surprise if they sell refurbished parts as new.
__________________
  #129 (permalink)
Old 07-27-2012, 10:04 PM
Junior Member
martin58boobhat is on a distinguished road
Default p.c. receiver board
is ther any way of checking the p.c. receiver board with a volt meter or other tool
  #130 (permalink)
Old 07-30-2012, 05:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
No. Whirlpool did not provide such instructions nor any diagrams for this parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
