Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Originally Posted by Andrew621 ...Can you tell me what shorting M&N does... It does nothing. M - is for motor
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #111 (permalink)
Old 04-12-2012, 03:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
It does nothing. M - is for motor and N - is neutral.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #112 (permalink)
Old 05-21-2012, 10:01 PM
Junior Member
apocalypsesrt is on a distinguished road
Default
I am so confused. My KSCS25inss00 is reading 45Vac across L&N. When i close my emitter flapper the light still blinks 2x per second and when i jump the water test nothing happens... I recently put a new water solenoid in and tested all the lines and had water working in from both sides but nothing in the freezer. There is no ice and i need to get this thing working.. Please help???
  #113 (permalink)
Old 05-22-2012, 03:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by apocalypsesrt View Post
...is reading 45Vac across L&N. When i close my emitter flapper the light still blinks 2x per second...
Both of these symptoms are leading to a bad optic boards.
- The optic boards kit Part number: 4389102
Here are the breakdown diagrams and Replacement parts for Whirlpool KSCS25INSS00 REFRIGERATOR | AppliancePartsPros.com
__________________
  #114 (permalink)
Old 05-24-2012, 05:20 PM
Junior Member
Default
So i replaced the optics, and i retested and the LED is working when i close the flapper and now im only reading 85Vac. When i short the leads to get water out there is nothing. Cant even here the solenoid engage.
I think im going to replace the whole ice maker now. I already did the optics and the water solenoids.
  #115 (permalink)
Old 05-24-2012, 06:19 PM
Junior Member
kjohnson014 is on a distinguished road
Default kscs25ftms01 not dispensing ice
Gene,
My IM makes plenty of ice and the water dispenses, but it will not dispense ice thru the door. The flapper door opens, but the auger motor does not turn.
The light flashes twice with the side flap released and is solid red when I manually depress the flap.
Where would you recommend I start troubleshooting?
Thanks!
  #116 (permalink)
Old 05-26-2012, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by kjohnson014 View Post
Gene,
Thanks!
Check the IDI auger motor as described in the attached file.
- The auger motor Part number: 2252130
Here are the breakdown diagrams and Replacement parts for Whirlpool KSCS25FTMS01 REFRIGERATOR | AppliancePartsPros.com
File Type: doc In-Door-Ice motor removal and testing.doc (1,008.0 KB, 14 views)
__________________
  #117 (permalink)
Old 05-30-2012, 05:59 AM
Junior Member
jhn0002 is on a distinguished road
Default Whirlpool GCSHEXNS not cooling on either side. Help!!
Woke up this morning and my Refrigerator and Freezer are not cooling. They are both around 47 Degrees F. When I open the freezer door, the red light blinks twice then twice then twice. Please help!!
Model number GC3SHEXNS Whirlpool Side By Side
  #118 (permalink)
Old 05-30-2012, 12:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does the compressor run?
Do the fans inside the freezer and on the back of the fridge run?
The model number you posted is incomplete. Verify and repost it please.
__________________
  #119 (permalink)
Old 05-30-2012, 12:52 PM
Junior Member
Default
GC3SHEXNS00
It sounds normal. fans are running, lights are on, everything as expected. We recently had a power surge which popped the majority of our breakers. This is likely what caused the issue.
  #120 (permalink)
Old 05-30-2012, 01:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pull the refrigerator out of the wall. Remove the cover and make sure the compressor is running. You have to feel some vibration on a touch. Also check it's temperature. Post the results.
It's also a good time to clean the condenser.
Here are the breakdown diagrams and Replacement parts for Whirlpool GC3SHEXNS00 REFRIGERATOR | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
