Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Originally Posted by Gene Hi Paul, If the LED is flashing while the flapper is closed, the beam is not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #101 (permalink)
Old 04-05-2012, 08:51 PM
Junior Member
ianflyboy is on a distinguished road
Question Icemaker not working
Quote:
Originally Posted by Gene View Post
Hi Paul,
If the LED is flashing while the flapper is closed, the beam is not blocked and the door light switch is not pushed in, then the problem is a bad optics. The solution is to replace both optic boards.
- The optic boards kit Part number: AP3137510
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRP25FNSS00 REFRIGERATOR | AppliancePartsPros.com
Hi Gene
I have Kitchenaid model KSCK25FVMS01. Icemaker was working intermittently now not at all. Water dispenser works, new filter. LED flashes twice with door open. Twice with beam flapper closed. LED is out with flapper closed and door switch pushed in simulating door closed. From previous threads this appears to be NOT normal. Am I correct in this conclusion? What is my next step. Thanks!
Ads By Google
  #102 (permalink)
Old 04-10-2012, 10:19 AM
Junior Member
jflatley is on a distinguished road
Default
Gene,
Read through this thread and have tried all the fixes with no luck. Icemaker is not making ice. Jumped all combos but get no reaction, line tested L and N for 120V ac (checks good) - new motor I purchased from you last year thinking that was the problem - didn't fix it and had given up. Troubleshooting again today to see if there is something I overlooked, but think I've tried everything except replacing valve. Any other suggestions before I go to that step?
Model KSRA25FKSS00
  #103 (permalink)
Old 04-10-2012, 11:49 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by jflatley View Post
Gene,
Model KSRA25FKSS00
1. Did you check the water feeding tube into the ice maker for ice inside?
2. Did you swap the wires between the water inlet valve solenoids and check for water inside the ice maker after pressing the water dispenser lever?
If you did both tests and the results were negative, replace the water inlet valve.
- The water inlet valve Part number: AP5263471
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRA25FKSS00 SIDE-BY-SIDE REFRIGERATOR | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #104 (permalink)
Old 04-10-2012, 01:22 PM
Junior Member
Default
Did all that with negative results. Ordered the inlet valve. Thanks for the quick reply.
  #105 (permalink)
Old 04-10-2012, 02:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #106 (permalink)
Old 04-11-2012, 03:35 PM
Junior Member
Default
Wow - ordered parts yesterday afternoon, and received them before noon today. I'm impressed.
Installed valve and now the ice maker is up and running like new.
  #107 (permalink)
Old 04-11-2012, 03:54 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad it's up and running.
__________________
  #108 (permalink)
Old 04-12-2012, 12:46 PM
Junior Member
Andrew621 is on a distinguished road
Default
Gene, thanks for all of your info on this thread. I'm pretty confident what my next steps are now. I just wanted to confirm the information on the test points on the Control Module. My wiring diagram does not show them and the only reference I saw on this thread was on 07-01-2011 and it didn't clearly lay things out. Model is KSRG22FKSS15. The troubleshooting was a bit frustrating because the trouble changed a couple of times.
Please confirm or correct:
L&N - 120V input. Powers the module. The Emitter and Receiver must be working for the power to be there. The black wire on the ice maker is a fusible link which could also be the problem.
H&T - If 120V is present, shorting H&T will bypass the bi-metal strip and the Control Module motor will run initiating a harvest cycle.
L&V - Shorting will dispense water.
M&N - ?????
H&N - Shorting powers the heater to the mold releasing the ice.
Thanks again Gene. From here I can actually see the United States but as you don't ship here I'm going to have to satisfied with your assistance and paying double the price for the parts locally.
  #109 (permalink)
Old 04-12-2012, 02:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Andrew,
Everything you wrote is correct, but you did not mention what exactly is wrong with it?
__________________
  #110 (permalink)
Old 04-12-2012, 03:18 PM
Junior Member
Default
Sorry, I am going to be replacing the Emitter/Receiver kit.
When it first quit working the fingers on the ejector were sticking straight up. It had locked up in mid-harvest cycle. I took out the ice maker and cleaned out the ice, took out the Emitter and Receiver and cleaned off the lamp and lens. Put everything back together and it started working. Went well for two cycles then quit again. Now I'm just getting the two flashes repeating and no 120 to the ice maker harness. Going by what I've been able to figure out from your recommendations the first step will be to replace the kit. Can you tell me what shorting M&N does, if anything. I'm making notes in the manual for next time.
Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
