Discuss
Ice Maker Not Working KitchenAid
 in
Refrigerator & Freezer Repair
Very likely the problem is a bad ice maker. I do not recommend to fix the existing ice maker because
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Not Working KitchenAid
  #91 (permalink)
Old 01-10-2012, 05:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely the problem is a bad ice maker. I do not recommend to fix the existing ice maker because we don't know exactly which parts to replace and very low rate on successful ice maker repairs.
AppliancePartsPros will definitely take back any parts you purchased from the company, but I would recommend to replace the ice maker first. Then check it with the new optics and, then with the old kit. Only when you'll be sure it does work with the old kit, return the new one. You have 365 days for returns.
- The ice maker Part number: AP3182733
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #92 (permalink)
Old 01-11-2012, 07:04 PM
Junior Member
webhale is on a distinguished road
Default Kitchenaid Ice Maker not working
Gene,
I assume that I need to replace the ice maker unit on a KSBS25INBL00 Kitchenaid base on the conclusions above. I have 120V power through points L & N, but the jumper in T & H did not produce any movement. Do you agree, or is there some other possible solution?
  #93 (permalink)
Old 01-12-2012, 02:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
You may want to run the test described in the attached file. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSBS25INBL00 REFRIGERATOR | AppliancePartsPros.com
__________________
  #94 (permalink)
Old 01-12-2012, 06:27 PM
Junior Member
Gene,
I did the manual start procedure, but the Ice maker did not run.
  #95 (permalink)
Old 01-15-2012, 04:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
John,
Looks like the ice maker has gone bad. You can use the same ice maker as listed above.
__________________
  #96 (permalink)
Old 01-18-2012, 12:36 PM
Junior Member
Eds 3rd is on a distinguished road
Default KitchenAid Ice Maker Not Working
Greetings Gene,
I'm the guy (Eds 3rd) that had the inoperative ice maker on the KitchenAid Refrigerator (Model # KSRP25FNSS00). Anyway, I followed your advice and ordered the entire IM assembly and "presto", everything worked as advertised. Once I knew everything was working as advertised, I unplugged the fridge and swaped the optics P.C. kit (emitter & transmitter boards) and plugged it back in.
Again, "presto", everything worked good. I must admit that I was a bit skeptical that AppliancePartsPros would take back this part (especially since it is an electrical item and most appliance parts stores will not accept a return), but was glad to hear that I will get a "Full Refund"!!
I am completely overwhelmed with this company and sent them an e-mail expressing my appreciation (especially the exceptional troubleshooting assistance I received from you -- Thanks again for everything)!!
Rest assured that I will use you exclusively for all future appliance parts purchases and will recommend you to all of my friends. GOD BLESS!!
  #97 (permalink)
Old 01-18-2012, 02:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. Thank you for your good words!
__________________
  #98 (permalink)
Old 01-18-2012, 02:50 PM
Administrator
APP Team
Adam / APP Team is on a distinguished road
Default
Quote:
Originally Posted by Eds 3rd View Post
Greetings Gene,
Thank You Eds 3rd,
Glad to hear you are satisfied with our service.
Also know that any part purchased from us within a year has a replacement warranty. Which means you dont need to return the defective part purchased from us. We just send you out a replacement and you hold the defective part for 30 days before discarding.
Please call our toll free number 1-877-477-7278 if you have any questions.
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices.
Thank you for supporting our free repair help forum.
  #99 (permalink)
Old 03-14-2012, 01:04 PM
Junior Member
Ppaolillo is on a distinguished road
Default Ksrp25fnss00
Ksrp25fnss00
The side by side frig is having an issue. The ice maker is not working. The status lights when having the freezer door open. And holding the left most white flapper held down. The status led on the right flashes twice and then one second off. And then repeats two flashes also having a second spacing. Blinking.
I have checked the valve seloniod the one to the water works when one pushes the water handle down it puts 5vdc across the seloniod and it makes the water flow.
On the same valve there is another seloniod for the ice maker. It seems that one is not getting a voltage applied.
As a check. I swapped the water glass seloniod connector with the ice maker seloniod input. They were not interchangeable due to the connector types so I simply held it implace to the ice maker seloniod and had someone type to fill a glass of water. As soon as I did that the seloniod activated the pump and water was successfully flowing out of the ice maker feed line.
I then buzzed out the original ice maker seloniod wiring successfully back to the top of the ice maker.
That tell me the wiring is good to that point. If I disconnect the inline connector that will disconnect the ice tray itself.
It is clear to me that the ice maker tray is not turning on the water valve to the ice maker. It is either in the tray itself or the control led beam. I tried to use a camera to see the flashes of the infrared transmitter In doing that I did not see a beam which would suggest te transmitter may be bad. The control board on the right side was removed. No visable scoring was detected on the board. Can someone help.
Paul
  #100 (permalink)
Old 03-14-2012, 06:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Paul,
If the LED is flashing while the flapper is closed, the beam is not blocked and the door light switch is not pushed in, then the problem is a bad optics. The solution is to replace both optic boards.
- The optic boards kit Part number: AP3137510
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRP25FNSS00 REFRIGERATOR | AppliancePartsPros.com
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid Ice Maker no working lavellino Refrigerator & Freezer Repair 1 10-23-2009 12:35 PM
kitchenAid ice maker not working sambino69 Refrigerator & Freezer Repair 0 10-07-2009 05:57 PM
KitchenAid Ice Maker Not Working Brian John Refrigerator & Freezer Repair 1 07-28-2009 04:22 PM
KitchenAid Ice Maker not working jkcpa Refrigerator & Freezer Repair 0 06-03-2009 09:55 PM
Ice Maker Not Working - KitchenAid mames Refrigerator & Freezer Repair 0 04-13-2009 09:55 AM
