The ice maker had been intermittent for a while and then stop altogether.
I check the wiring harness and it was good. Checked the water valve. Even jumpered Black to Brown and got water to flow.
So I replaced the ice maker with an AP4135008.
Still no ice. Measured 120 v from L to N.
Checked the freezer temp and over 15 hours it was +7 to -6.
Jumpered T-H and it ran a cycle, but did not run any water.
Jumpered T-H and measured from V to N and got 109 v during the fill cycle, but no water.
Jumpered L to V and got water to fill the tray.
So is the replacement ice maker causing 109 v on the V terminal?
Or is it designed to do that and the valve should work with 109 v?
