I have a GE GDS18SCR 6 years or older... Lately the door seal does not have that tight close that it used to have.
I checked to see that nothing was blocking the door, checked the seal, and hinges, but it does not have that(vacuum like) grab that seals tight.
If I push it shut is grabs a bit and stays sealed, though not much grab.
Is there a device within (or a magnetic strip) that creates this 'draw' that seals the door shut? Roger
