My freezer is making a loud buzzing noise when I plug it in. I moved about two year ago and have not used it since the move. I believe the noise is coming from the compressor. Is it the relay, overload or the compressor? Can I change the relay or overload with basic tools? Thank you, Brad
How much time have you given it to see if the noise goes away?
NONE...It was so loud that I unplugged it right away. Originally Posted by: magician59 How much time have you given it to see if the noise goes away?
