Discuss
Uline runs then stops and won't start after defrost
 in
Refrigerator & Freezer Repair
I recently got a great deal, so I thought, on a scratch/dent Uline bar refrigerator. The unit looked brand new
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Uline runs then stops and won't start after defrost
  #1 (permalink)
Old 09-04-2011, 07:57 PM
Junior Member
loyance is on a distinguished road
Default Uline runs then stops and won't start after defrost
Model Number: u-c029fb-00   Brand: -other-   Age: Less than 1 year
I recently got a great deal, so I thought, on a scratch/dent Uline bar refrigerator. The unit looked brand new inside and out other than the door hinge. When I first plugged it in the fan in freezer turned on but the compressor never came on. After running for a couple of hours without cooling down, I started to investigate. I pulled the front grille off and found a small dial. When I turned the dial the compressor came on and immediately started cooling and making ice. I thought everything was perfect. The next morning I checked on it. The fan was running, the compressor wasn't, and my ice had all melted. :-/
I then decided to call Uline customer support for a little help. They informed me that the dial I had turned was the defrost timer. Since I could turn the dial one click and it would start functioning properly, he determined that the defrost timer must be defective. So, I ordered a defrost timer and installed it no problem. Much to my dismay the refrigerator was still having the same issue. :-(
I then decided to bring in a "professional". I paid $89 to have a "Factory Certified Technician" come look over the wiring diagram, then trace a few wires. He concluded that since he had been on the job for the minimum hour time and couldn't figure out what was wrong that he would give up, take his payment and be on his way. He said if this was a new unit based on the troubleshooting he did that U-Line would normally replace the unit but since I didn't by it new I'm out of luck. His final reach for an answer to give me was that there might be a short in a hidden wire somewhere.
Having said all that.......Can anyone offer any solution to my problem- something to look at, suggestion of what to possibly replace, perhaps reason to check the thermostat, etc? I'd hate to just throw the unit out.
Any help would be so greatly appreciated.
Lance
Related Models
Hoover U1025---
Magic Chef U11GA-1 RANGE- F/S STD GAS
Magic Chef U11GA-1-GG RANGE- F/S STD GAS
Magic Chef U11GA-1K RANGE- F/S STD GAS
Magic Chef U11GA-2KW RANGE- F/S STD GAS
Magic Chef U11GA-2W RANGE- F/S STD GAS
Magic Chef U11GN-1 RANGE- F/S STD GAS
Magic Chef U11GN-1-GG RANGE- F/S STD GAS
Magic Chef U11GN-1K RANGE- F/S STD GAS
Magic Chef U11GN-2KW RANGE- F/S STD GAS
Magic Chef U11GN-2W RANGE- F/S STD GAS
Magic Chef U11GY-1 RANGE- F/S STD GAS
Magic Chef U11GY-1-GG RANGE- F/S STD GAS
Magic Chef U11GY-1K RANGE- F/S STD GAS
Magic Chef U11GY-2KW RANGE- F/S STD GAS
Magic Chef U11GY-2W RANGE- F/S STD GAS
Magic Chef U11HA-10 RANGE- F/S STD GAS
Magic Chef U11HN-10 RANGE- F/S STD GAS
Magic Chef U11HY-10 RANGE- F/S STD GAS
Magic Chef U11JA-2KW RANGE- F/S STD GAS
Magic Chef U11JK-2KW RANGE- F/S STD GAS
Magic Chef U11JN-2KW RANGE- F/S STD GAS
Magic Chef U11JS-2KW RANGE- F/S STD GAS
Magic Chef U11JY-2KW RANGE- F/S STD GAS
Amana U1200I COMMERCIAL MICROWAVES
Amana U12F FREEZER- VERTICAL
Amana U13K FREEZER- VERTICAL
Amana U13K-A FREEZER- VERTICAL
Amana U13K-AG FREEZER- VERTICAL
Amana U13K-C FREEZER- VERTICAL
Amana U13W FREEZER- VERTICAL
Amana U13W-A FREEZER- VERTICAL
Amana U13W-AG FREEZER- VERTICAL
Amana U13W-C FREEZER- VERTICAL
Amana U15F FREEZER- VERTICAL
Amana U1600D COMMERCIAL MICROWAVES
Amana U1600I COMMERCIAL MICROWAVES
Amana U1600S COMMERCIAL MICROWAVES
Amana U16K FREEZER- VERTICAL
Amana U16K-A FREEZER- VERTICAL
Amana U16K-AG FREEZER- VERTICAL
Amana U16K-C FREEZER- VERTICAL
Amana U16W FREEZER- VERTICAL
Amana U16W-A FREEZER- VERTICAL
Amana U16W-AG FREEZER- VERTICAL
Amana U16W-C FREEZER- VERTICAL
Amana U18F FREEZER- VERTICAL
Amana U18K FREEZER- VERTICAL
Amana U18K-A FREEZER- VERTICAL
Amana U18K-AG FREEZER- VERTICAL
Amana U18K-C FREEZER- VERTICAL
Amana U18W FREEZER- VERTICAL
Amana U18W-A FREEZER- VERTICAL
Amana U18W-AG FREEZER- VERTICAL
Amana U18W-C FREEZER- VERTICAL
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
runs and stops Blake1111 Dryer Repair 1 06-23-2011 03:32 PM
Ice maker stops, freezer stops, defrost it works geezer60 Refrigerator & Freezer Repair 0 12-30-2010 04:52 PM
dryer start but stops when I release start button vchss360 Dryer Repair 7 10-20-2009 03:46 AM
runs for a few minutes and stops FISHMASTER70 Dryer Repair 8 09-17-2008 07:34 PM
dryer runs then stops mike_T Dryer Repair 0 09-04-2007 05:41 AM
