The water dispenser will not work. This is a Whirlpool side-by-side refrigerator/freezer unit, bought new about 6 years ago. The ice-maker is still making ice. I have not replaced the filter because it was replaced 6-8 months ago. Any ideas on what might be broken would be appreciated.
Thanks, Trav
Had same problem , have same side by side. Could be water solenoid or frozen coil in bottom of fridge, but probable frozen water line in freezer door. I changed out my double water inlet(water and ice separate), replaced filter, and worked with water reservoir coil before leaving freezer door open and it started working. Found the freezer was to cold, or door not padded:)
Originally Posted by: tigra9@earthlink.net Had same problem , have same side by side. Could be water solenoid or frozen coil in bottom of fridge, but probable frozen water line in freezer door. I changed out my double water inlet(water and ice separate), replaced filter, and worked with water reservoir coil before leaving freezer door open and it started working. Found the freezer was to cold, or door not padded:) Thanks much for the tip. I'll look to see what the temp is set on. How long did you leave it open? A half-hour or so? Thanks, Trav
