Hi, I need help with ice maker. Water was dripping into tray, so I ordered replacement valve here. The replacement has only 1 solenoid valve. This matches picture. However I cannot locate this valve on fridge. The only ones I see have 2 solenoids, located at bottom. Is there another valve behind icemaker or rear panel?
Hello John. Based on the model number you provided, there is two valves. One is behind the rear panel. The other is visible from the back. You will need to order the secondary valve behind the panel to repair the leak. Here is a link to the part and the diagram page. Hope this helps. Part number: AP4009555
